1 - 20 of 34 Posts
Discussion Starter #1
ok time for a little lesson on these :
1-if you dont understand relays and diodes-DO NOT attempt this installation!!!!
2-if you want to do these newer vehicles, say 99 1/2 and up, you WILL NEED a bypass for the transponder, and you will need to use your VALET keys
3-im going to attempt to answer as much as i can with out getting too technical, and it doesnt matter if it's a manual or not, EITHER of them can be done with the RIGHT parts
now the golf and jetta are pretty much the same install, with ONE exception---if your doing an alarm and remote starter combo unit, you need to wire each door individualy to the alarm--here is the reason why---when the remote starter engages, it needs to disarm the factory alarm first---this does the following, it unlocks the driver door and turns on the interior lights---now if you added an alarm to the vehicle, the alarm thinks a door was opened and it will trigger the alarm to go off----now the easiest way to do this is the add an additional relay to break the interior light wire from the alarm, but understand you lose security of the vehicle then-----now if you wire each door individually you will not lose any security, but you will need to run wires into each door and install diodes in each door to elimate any chance of backfeeding the circuit----this is issue #1 ----now on too issue #2----the transponder bypass----awhile ago we were using a universal transponder bypass, it basically has a ring on it that transmits only under remote start----well it was very picky aboout where it was installed----then a new version came along to be used in bmw's that was better suited for the install in a vw----DEI part# 555B -----this is the only 1 i will use currently in a new VW----it is working flawlessly in 2 gti's at work(we love VW's there )--and also for all our vw customers-----dont waste your time with other ones---ok issue #3-----door lock integration is actually easy in this vehicle----with the exception of wiring it in the rear of the front driver door---the trunk release can also be accessed in the door, if your running 2 wires in there, a third isnt that mucch harder----ok issue #4---manual or automatic??? ----IT DOESNT MATTER---the clutch is a simple 2 wire switch, that you will need a relay to integrate to----extremely easy clutch to bypass actually---and if you do it correctly, it will only bypass when under remote start-------ok issue #5----WHICH alarm/remote start to get??? heres my list that i have personally done on newer vw's:
Clifford Solaris (has everything you need for either manual or automatic!!!!)
Autopage rs650
Autopage rs750lcd
Clifford Intelliguard 8000 w/ Intellistart 4--(also does both manual and automatic)
Viper 790xv
Viper 550esp
Avital 3300 (basically a viper 550)
Avital 6501 (old unit, not produced anymore, but there are some still around)
anyway, they all worked fine, with the best one being the Solaris for integration of the factory alarm, and remote starting on manual or automatic
hope this helps a little---if you need more info, or need technical help, feel free to email me : [email protected] if you need immediate assitance i can be reached via AIM: phd12vxxx my cellphone has AIM on it, send me a message with your phone # and the make model year of the vehicle you need help on ok?
and by the way---FIND AN INSTALLER THAT KNOWS THESE VEHICLES---ive heard some serious horror stories from other people about lack of knowledgable installers at best buy and circuit city when it comes to these cars---just a heads up
issue #6--------you need to turn off the igntion lock/unlock after installing these units---forgot about that one ---and then issue #7----split parking light wires ----you will need 2 6amp diodes with the bands facing away from the remote starter--once again, if you dont understand diodes and relays, have it done by a pro
now here are some specific wiring instructions for some specific vehicles:
DOOR LOCK WIRING
what we are basically doing is getting to the key cylinder wiring. the factory uses 2 wires coming from the driver door key cylinder to arm/disarm the factory alarm--if you were to wire additional relays to these wires, and hold the pulse going to the wire, your windows will go up and down respectively
mk4's-Jetta/Golf/GTI
LOCK WIRE= yellow/blue in the driver door
UNLOCK WIRE= green/red or yellow/green in the driver door
these 2 wires are in the rear mosr portion of the driver door, they are a NEGATIVE pulse system---1 pulse on the LOCK wire will lock all doors, and arm the factory alarm. 1 pulse on the UNLOCK wire will disarm the factory alarm, and unlock the driver door only. Most newer alarm systems have a programming feature for double pulse unlock, you want to program this to ON. This way you will unlock all doors, and disarm the factory alarm in one shot---as a note, if your alarm remote starter unit has thin wiring that flips its polarity depending on the vehicle, you best bet is to put relays on the wires ---i have in fact gotten it to work with 1 amp diodes, but i dont recommend it--(i was in a pinch)
DOMELIGHT WIRING INFO
If your only installing an alarm, then you will want to go directly to the wire at the factory alarm, it is a blue/gray wire and is a NEGATIVE TRIGGER. Now if your doing an alarm/remote starter combo unit, you will do this one of 2 ways, you will either need to add a relay to interrupt the door trigger when under remote start, or wire each door individually with diodes (3amp) installed in the factory lines. Bad side to this is if you interupt the door trigger wire, you lose the door trigger for security reasons while under remote start. GTI's only have the 2 front doors, so its not that much of an ordeal, the jetta's and 4 door golfs are more of a pain. the reason for this is stated above as issue #1
PARKING LIGHTS
OK, this is the easiest of the bunch, VW has split parking light wires on their cars. Take the single wire output from your alarm(should be a + output) and your gonna need 2 6amp diodes . Take the diodes in your hand, notice one side has a silver band on it?? good. take the OTHER side and solder those 2 ends together. those 2 ends will be soldered directly to the output from the alarm system. take the BAND ends which are still seperate, and solder a wire to each one---you should end up with a Y-looking wire---insulate both diodes too---now you have 2 wires to hook up to the factory parking light wires. pull out your factory headlight switch, and look for the gray/red and the gray/black wires---these are your parking light wiresconnect each end of the wiring you just made to each wire. the diodes keep this circuit from backfeeding into each other, as an FYI
i will try and edit this more as time allows
WIRING DIAGRAMS OF PASSAT/GTI/JETTA/Cabrio
WARNING:USEAT YOUR OWN RISK
MK4 JETTA/GTI/GOLF WIRING
12volts red + ignition harness
Starter red/gray + ignition harness
Ignition black + ignition harness
Accessory black/red + ignition harness
Power Lock yellow/blue - driver door module in door
Power Unlock green/red or yellow/green - driver door module in door
Notes: A double pulse will unlock all doors and disarm the factory alarm.
Parking Lights+ gray/red and gray/black + driver kick panel
Door Trigger blue/gray - comfort module
Notes: The comfort module is the main control module located under the driver side of the dash.
This wire will read the dome light delay. To avoid the dome light delay, use the separate door trigger wires and diode isolate each one. They are brown/white and are all located in their own door at their own door module.
Dome Supervision blue/gray - comfort module
Trunk/Hatch Pin brown/black or brown/blu - comfort module
Hood Pin brown/red - comfort module
Trunk/Hatch Release green/brown - comfort module
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Tachometer NOT black/purple or brn ac any ignition coil
Brake Wire red/black + driver kick panel
Horn Trigger black/yellow + comfort module
2000 CABRIO WIRING
12volts red 10 ga. + ign. harness - big
Starter red/black 10 ga. + ign. harness-big
Ignition black 16 ga. + fuse box
Notes: There is a positive trigger key sense wire at the ignition switch or in the radio harness. the wire color is brown/red.
Accessory black/yellow 12 ga. +
Power Lock gray + driver door harness in kick
Power Unlock green + driver door harness in kick
Notes: Requires a double pulse to unlock.
Parking Lights+ gray/red, gray/black back of lt.switch
Notes: Hidden release tab for light switch on upper left side of switch. Use relays to isolate the switch side of parking light wires from seeing 12v, or the igniton circuit will pulse with the light flash. It is also possible to use the hazard lights. The colors are black/white and black/green, and are positive trigger. They can be found at the alarm module or steering column.
Door Trigger brown/white - dr. kick or alarm mod
Notes: The alarm module is located behind the headlight switch.
Trunk/Hatch Pin brown/black - dr. kick or alarm mod
Hood Pin brown/red - at alarm module
Trunk/Hatch Release gray switch
Notes: Gray wire grounded by switch at rest. Use a relay to isolate the switch side of the trunk release wire from seeing 12v.
Factory Alarm Arm same as lock +
Factory Alarm Disarm same as unlock +
Notes: Use a single pulse to disarm without unlocking.
Tachometer black/red at coil on firewall
Brake Wire red/black + brake pedal switch
Horn Trigger black/yellow + alarm module
2002 PASSAT WIRING
Starter red/black + ignition harness
Accessory yellow/black + ignition harness
Power Lock red/green - in driver door
Power Unlock red/blue - in driver door
Notes: Unlock requires a double pulse. First pulse will disarm the alarm and unlock the driver door, second pulse will unlock all the doors.
Parking Lights+ green/red headlight switch
Door Trigger blue/gray - 23 pin plug, pin 21 @ CCM
Notes: The CCM (Comfort System Central Control Module) is mounted on floorpan in protective box, under the carpet in front of the driver seat.
Dome Supervision comes on with unlock
Trunk/Hatch Pin brown/black - 23 pin plug, pin 10 @ CCM
Hood Pin brown/red - 15 pin plug, pin 5 @ CCM
Trunk/Hatch Release brn/gry or brn/grn - 23 pin plug, pin 2 @ CCM
Tachometer ignition coil or coil pack
Notes: For tach go to one of the ignition coils or coil pack and use a wire that is NOT red/green or brown/yellow.
Horn Trigger blk/yel (alarm horn) + 15 pin plug, pin 11 @ CCM
Modified by phd-12v at 9:12 PM 1-5-2004
awesome info.....but I see a whole bunch of horror stories comming...from backyard "installers".....but none the less, kudos to you for taking the time to educate the guys in this forum
Re: Remote Starter Time again, info here!!! (phd-12v)
Thanks for all the detailed info! I have a question for you and will explain it as good as I can...
I have a Clifford Intelliguard 7000 installed with remote start and glass break sensor profesionally installed. The one issue that I have with it is when I arm the alarm.
Scenario 1. I park the car and get out, and arm the alarm 10 seconds after I shut the door. This will lock the doors (I will hear a honk (factory)), and the Clifford alarm will arm (I will hear a double chirp). So everything works fine.
Scenario 2. I park the car and get out, and arm the alarm right after I shut the door. The clifford alarm arms (I will hear a double chirp), but the doors do not lock(no honk).
Do you have an idea of what is not right with the wiring? or is this something that is the way it is?
I have taken it back to the installer, and they pretty much said that it works, and you just have to wait the little bit before you lock the doors.
PM me or shoot me an email @ [email protected]
Modified by 20v18t at 11:31 PM 1-6-2004
Discussion Starter #4
Re: Remote Starter Time again, info here!!! (20v18t)
since others may have the same question---ill post it here
on the clifford alarms---they have the interior illumination wire (brown/red) hooked up to ground---this wire does 2 things, 1 it tells the alarm what POLARITY your vehicle domelight is, and 2 it sends out a pulse when you disarm the alarm to turn on the factory domelight-----i had this happen and i completely forgot about it----heres the fix:
you will need to install a diode in the main door trigger wire going to the alarm---(band faces away from the alarm)---what this will do is keep the alarm from activating your domelight when you 1 turn off the car and 2 when you disarm the car---you dont need this feature, cause the factory alarm when disarming, turns your interior light on---do this and you wont have that delay anymore http://****************.com/smile/emthup.gif
p.s --- the way i finally figured this out was this---ask yourself a question--if you try and arm the factory alarm it wont arm with the door open huh??? when the output from the clifford stays on, your factory alarm thinks the door is still open--hence the delay on arming it!!!!
Modified by phd-12v at 10:00 PM 1-6-2004
2013 Passat SE 2.5, 2019 Atlas SE 3.6 4motion
great post phd, and ever heard of AstroStart we use those along with autopage at my shop, love em, and our installer who does all the remote starts can nock out 3 basic one in a day(2 if involving more and one if it is a whole system, i.e. remote start, security, and everything being programed) but yeah the info you posted is awsome http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif big ups to you. and like you mentioned b4 there are quite a bit of installers at best buy and curciut who do not know what they are doing, we get several "fix" installs a week that have come from best buy and curcuit and the owner had told us that best buy or curcuit had f-uped there car and try and charge them to fix it
whats up with that, at my shop if we mess anything up or something goes wrong(doesnt usually happen) we will bring you in and fix it for no charge as long as we installed it and no one else has tampered with it. that is another thing whats the deal with people who dont know anything about security systems trying to add there own **** in
lol when they come back saying we messed up there car we take there dash panels, knee bolster (and so on) off and find that thebrain is now relocated and wires have been exposed and not properly wrapped up or heat shrunk. we just look at them and laugh and tell them that we found the problem, it was an I D 10 T error and make money because they wernt smart enough to leave it alone.
Hey thanks a lot!!! Im going to call the installer tonight and see what they say. Ill keep you posted.
Great post. It still scares me to let someone less experiened work on putting remote starts or alarms in their cars. It has always been my experience that the install alone is the best defense for security of the car. Remote starts are a whole other ballgame; if you haven't done one before please do not attempt. There are just to many variables in putting them in. As far as the "lack of knowledge" comment; yes I know that there are those people out there that really aren't all that knowlegable, but let's remember that there are a few like myself who would bend over backwards to take care of you right. I work for one of those big chains because that is where the money is and let me tell you; before handing your car over to just any installer sit down and talk with them and lay out your plans for the car and if they sound confident enought go with them.
Discussion Starter #8
Re: Remote Starter Time again, info here!!! (kwalton)
excellent post, i agree with you 100%---yeah i know it was kinda weird to post the info, but it makes it easier when troubleshooting comes into play---i knew the comment about the big boxes would come into play at some point, i understand i work for one too- http://****************.com/smile/emthup.gif ---but i was asked last year by someone to post the pertinent info, and i did, so i reposted it this year, and then it was added in the faq section
also when guys are looking for wiring for turbo timers/stereo work, or anything electrical, i basically laid out all the wiring they may or may not need
Hey guys, I noticed in the list you didn't have the Compustar alarm/starter on your list...
I have to say my install is awesome and he did an a1 job on my install of this particular starter/alarm...(for anyone who isn't familiar with this starter/alarm, it is a 2 way pager and it is awesome cause it has a 1/4 mile range on it and for all you turbo users on it...there is a turbo timer built in to it. more on http://www.compustar.org look for the 2WFM series) The new ones have a range of 1.25 miles on it...WOW
I tells ya...nothing beats this...in my mind that is. Oh, the only thing is...if you have a 4 door with the alarm...you need to hook it up to all four door pins to get this particular one to work. Giddy-up http://****************.com/smile/emthup.gif
Banned
Re: Remote Starter Time again, info here!!! (DubRadio)
Quote, originally posted by DubRadio »
great post phd, and ever heard of AstroStart we use those along with autopage at my shop, love em, and our installer who does all the remote starts can nock out 3 basic one in a day.
Sorry to break the news to you man, but doing 3 remote starters in one day, lets say an 8 hour day just for the hell of it, isn't fast or impressive at all. Basic remote starters, say something without keyless entry, no bypass, will take about 20-30 minutes, including taking the vehicle apart, installing the unit (soldering every wire), and reassembly. On a slightly harder vehicle, say maybe one with keyless, bypass, trunk, all that good stuff, on average, will take about 45 minutes to an hour, at most. Even harder than average vehicles, ones where you have to go into the door for the keyless wiring or for the factory alarm disarm, trunk, etc., will take no more than an hour and a half at the longest. That works out to somewhere between 8-12 starters a day, on average, which I do EVERY DAY! Just thought I'd let you know.
Re: Remote Starter Time again, info here!!! (SalemNHGreenGolf)
Not to second guess your times, but it makes me wonder just how good these installs are. I have been doing this for 10 years proffesionally and the quickest cars out there for me are hondas. Now I don't know what you capabilities are but I consider myself to be pretty good and my record for most remote starts in a day is 6-8 depending on whether they are just remtote starts or keyless with alarms. Also. factor in immobilizers and I just don't think it's possible. My best day was a 12-14 hour day. These are also all DEI products.
One other thing - are you installing a hood switch and running a tach wire??
Discussion Starter #13
Quote, originally posted by kwalton »
ive done 9 in one day, keyless and remote start--8 had immobilizers and 2 had wiring in the door--(nissans)----that took about 14 hours straight---that and ive been doing this 14 years now---3 a day for me is a lazy day actually--and there is no way in hell, i could do 9 vw's in one day with an alarm and remote start---3 -4 would be pushing it for me---there is too many different variables when doing remote starts to say it only takes a certain time to do any car---every car is different in its own way---my easiest vehicles to do are camry's and civic's---which by the way,are always coming in-----give me 12 camrys, and ill be home in time for monday night football
Discussion Starter #14
yes --------
depends on the vehicle(if it actually has a tach wire then yes, if it has multiple coils, or just injectors, i usually go tachless, because of idiot dealers around here blaming squeaking brakes on a remote starter---you who do these, and have been doing them for some time, will understand
Banned
I know that my times that I listed above may no sound realistic, but I challenge you to find anything wrong with any of my installs. Every wire soldered, all wires taped to "blend" with the factory wiring, 99% of wires completely unfindable (if that's a word) when an alarm is also being installed, every thing done the right way. As far as using hood pins, have you seen the effects of one New England winter on a hood pin? Completely rust out, not worth the hassle. I install a toggle switch on the hood pin shutdown input, inform the customer of it's locatiion and function, and I had stickers made up for under the hood to warn any would be mechanic as to how to disable the system. Tach wires, 90% of the time, but as stated above, sometimes it is just less of a headache as an afterthought with doing it tachless, whether it be using a timed output for the cranking (DEI products) or using the average crank time of the last 8 times the vehicle was started by key (Code Alarm models.) I have quite a list compiled of alternate locations for obtaining a good tach signal, 90% of them being inside the vehicle, thus eliminating the time used to run wire to the engine bay.
As far as easiest vehicles to work on, I would definitely say late '99-'02 Chevy/GMC full size trucks and SUVs. Two 7mm screws, 4 10mm nuts, and the entire insall is right before your eyes, ignition harness and BCM, every thing but the tach wire is there, but just reach up behind the cluster for the tach. DONE! Record time on one thus far: 12 minutes, start to finish.
Discussion Starter #16
12 minutes?? it takes my soldering iron 12 minutes to heat up sometimes
I am sorry, but i just can't believe you!! yeah sure everything is right there in those trucks, but still what about a prewire on the bench and how about verifying the wiring?? Oh yeah how about the door locks in those vehicles? as far as going tachless tell me how reliable is that remote start when it 10 below and it is trying to read voltage off the battery. I am sorry but your statements just don't make me believe. oh by the way you also have a 10mm bolt holding the e-brake handle as well.
Banned
what the hell are you taking the ebrake handle out for? I hope it's not the door locks you are referring to, because you can get them at the BCM, right below the ignition harness, left plug, light blue is lock, white is unlock, right next to eachother.
And for the soldering iron taking 12 minutes to heat up, try butane, junior. Instant heat.
I was referring to the newer gm trucks with the one wire systems that you need a 455g or 456g,
Discussion Starter #20
Quote, originally posted by SalemNHGreenGolf »
i was kidding---and by the way, i have 3 butane ones, just in case
also,whats with the junior comment??? you have an issue with something, you would like to share with the class?
1 - 20 of 34 Posts
