1 - 9 of 9 Posts
Re: Remove sticker from tint (trance728)
I've heard a combination of razor blades and steel wool works wonders, takes that tint right off and gives you a crystal clear view!
Actually, there is this citrus stuff called De-Solve-It that breaks down the adhesive behind the sticker and works like a charm. If you can let it heat up in the sun that would probably also help.
i have the same problem a campus sticker that is like plastic or something but its real thin so i cant just peel it off, when i try to peel it breaks up into little pieces and i get very little off, tried wd-40 but its plastic so that dosent work and i have tinting too
please help
"kevin" at "anameless.com" without the "s
1 - 9 of 9 Posts
