Re: Removing a clipper kit - what do I need? (Cab42)
theres a couple of rivets to drill out where the arches connect to the bumps. youll need a drill, then, some wrenches for the bumps (19 or 21 mm? i cant remember - take a whole set), two jackstands and a set of screwdrivers. pliers to disconnect the turn signal wires.
oh, and some brute force. dont forget that. example, heres how to remove the front bumper skin and rebar:
>drill out the three rivets on the inside of the front arches, where they meet the front bumper
>get you fingers between the bump and the grille and pull the skin upwards. youll hear it pop. there are at least seven clips you need to pop up
>the bump skin is now only attached to the rebar with clips on the inside at the front. basically its stuck into holes on the rebar. you cant access them so you have the get some leverage and pull HARD. they will pop out. all 15-ish of them
>now take your wrenches to the rebar, it will be connected to the bumper bracket and that nut is probably frozen. if you cant get it off get under the car and remove both brackets then pull (hard) and the rebar will slide right out - careful, though, its heavy
rinse and repeat on the rear. side skirts are easier. arches will now just be held on with screws and tape.
