1 - 4 of 4 Posts
I'm going to be replacing my exhaust, and have a question about what people to do get rid of the parts after the cat.
Is it possible to wiggle out that pipe over the axle? Or will I have to cut it up to remove it?
-Nick
Re: removing cat-back (GTi Nick)
Quote, originally posted by GTi Nick »
-Nick
If you undo the rear bolts of the shocks then you could slowly lower the axle and take it out in one piece. If you don't have access to a lift and are working off the ground then you will most likely benefit from making 1 cut near the axle.
Jason
Re: removing cat-back (balance-del)
Quote, originally posted by balance-del »
If you have a saws-all or a cut off wheel it would be easier to just cut it!
And a lot more fun... its always to take out some aggresion http://****************.com/smile/emthup.gif
1 - 4 of 4 Posts
