removing door handle
849 Views 16 Replies 6 Participants Last post by  eastcoastdubs
Im trying to remove my door panel and have except it's sticking where the door handle is so i assume i need to take that off. How do i remove it?
to whoever answers first.
See less See more
1 - 17 of 17 Posts
Re: removing door handle (alphaDUB)
the inside handle? the trim around it slides off, slide it forward and it'll unclip, and come right off, then u can remove the panel.
Re: removing door handle (The_Hamster)
does the other handle, the one that u pull to close the door need to be removed too?
yes. the cover on it pops off, stick a screw driver into the bottom of it and pull out, under are 2 phillips head screws, back in there.
yeah you need to remove everything on the inside of the door first. There is a little inside trim on the door pull, you just pull that off and you will see two big screws holding the door card on. You also have to remove the ash tray, window crank, etc.
i assume u also go the window winder, it's cover also pops off to reveal a phillips head, and the mirror adjuster if it's a manual mirror. then 4 screws around the otuside of the panel, phillips again, and take out the lock popper thing, and the cover/trim thing underneath it. now the panel will slide off, pull fromt he top, the bottom goes into soem clips that it'll come right out of no problemo.
Great thakns a lot guys happy thanksgiving. im installing new speakers in my doors. I have some passive crossovers should i put them in the door?
you cutting holes in the door panel?
much better way to do that is get teh stock map pockets from 88+, some had a speaker grill with them, or u can get them at the dealer. 5.25" speakers bolt right into there, no problemo, look into that before cutting the actual door panel.
as far as the crossover goes... wherever i guess, may get some water on it in there, or moisture, so inside the car might be better, under the dash or something.
See less See more
here's the door pockets with speakers in them, the top ones are 4.5" i jimmy-rigged to get to fit as you can see, and the bottom are what OEM ones look like with the grill etc.
See less See more
Yeah im definately using the speaker holes in the map pockets.
Damn, I never new it takes all that just to take the door panels off. I have to do that this weekend also. My passenger side door handle is out of alignment with something. I have to open it from the inside. http://****************.com/smile/emthdown.gif
See less See more
Re: removing door handle (eastcoastdubs)
DONT MOUNT YOUR CROSSOVERS IN THE DOORS !!
Water and Crossovers don't like each other...
Kritter
Re: removing door handle (Kritter)
I say do it. and this is why. You take 2 plastic baggies and after you wires everything up you put them in plastic baggies. a couple people I know including myself have done this with success. Make sure you ziptie the end where the wires come out tight. try to mount it so the wires are going down with the opening of the bag. good luck
did your outside door handle ever work or did you just recently have to start opening it from the inside?
Re: removing door handle (The_Jerbel)
I'm not sure, i just got the car monday. Its been siting for awhile. he did say something about the car being broke into so that might be it.
you did it didnt you!!!
came all the way from Canada to break into some invaluable sloppy muricans car aye?
[Modified by eastcoastdubs, 1:32 PM 11-23-2001]
See less See more
2
MUUUAAAHAHAHA DAMN RIGHT! About time you caught me! stupid slob murican...
So something might be bent inside or the door handle could be broken. Take the door handle off, look inside the door and see for yourself, takes all of 2 minutes.
See less See more
dats what i plan either tonight if i can find a good light source or tomorrow morning. TGIF
1 - 17 of 17 Posts
