1 - 2 of 2 Posts
Does anyone know how to get the headlight cover off? I finally received my Hella Bi-Xenon headlight but there's alot of junk on the inside of the cover. I'd like to clean it before I install it. I can see some metal clips that "hold" the cover againt the housing, are those all I need to take off? Thanks.
Re: Removing headlight cover on Passat B5.5 Hella Bi-Xenon? (Big Mac)
I don't think you can take off the cover at all - AFAIK the lens is molded/glued to the housing, and if you pry off the metal clips you probably can't put'em on again.
1 - 2 of 2 Posts
