1 - 20 of 24 Posts
Discussion Starter #1
i bought some disk for my cabby
am looking to clean the rust on the disk
is there a chemical or some home trick
i can try for this???
Re: removing RUST???? (Johann_VW)
Quote, originally posted by Johann_VW »
i bought some ROTORS for my cabby
am looking to clean the rust on the ROTORS
Why buy used rotors, if brand new ones are not expensive at all???
*If I interpreted that correctly...
Re: removing RUST???? (ReRa1)
Quote, originally posted by ReRa1 »
x2
Re: removing RUST???? (broken dipstick)
Quote, originally posted by broken dipstick »
in puerto rico
rotors are like gold.
road trip?
Banned
i'll inflate my tires a lot so they can float like a raft
Get banned and go back to brobs.
Banned
Re: (huskylord)
put the rotors on your car, drive around, and brake a lot. then the rust is gone.
Modified by NeveruN at 3:37 PM 11-2-2007
Re: (NeveruN)
Quote, originally posted by NeveruN »
put the rotors on your car, drive around, and break a lot. then the rust is gone.
Have NEW PADS HANDY!
I doubt any chemicals can remove rust without touch....
Sand them well...
'84 GLi
Re: (NeveruN)
x1,000,000
ive had a car sit for a while and had rusty brakes, drive it and the rust comes right off. but if the rust is deeply pitted then theres nuthing you can do for them. it feels weird at first , just dont expect to stop on a dime the first few times.
Re: (BuzzKilla)
Just drive the car - rust comes right off.
Rotors rust.
They are made of steel.
Steel rusts.
Rust is an oxidation process - whereas the rust is exposed to oxygen and moisture and it slowly "burns" away.
2Fe + O2 + 2H2O = 2Fe(OH)2
http://en.wikipedia.org/wiki/Rust
Grind sand if off, and paint the area of the hat if needed - this will prevent the rust. However - the rust that forms on the brake friction contact area is non avoidable.
Modified by Dan J Reed at 12:57 AM 11-3-2007
1 - 20 of 24 Posts
