1 - 6 of 6 Posts
Sooooo, i've went through 3 autozone starters; they all seemed to work for the first 10 starts then died. I just recently had the original starter rebuilt for 55 bucks and he even tested it in front of me and it worked great Then.....i get home install it and nothing, nothing at all?? Ok, i replaced the copper bushing(sleeve) the battery is reading 12 volts, and i put in a new ignition switch. So now i just wanted to ask the community what you thought, because now this problem looks like it might be more than the starter itself, anyway, im completely lost here.
Any feedback would be great. I just want my car to start!!
did you replace the starter bushing its only like 65 cents and it can casue starters to go bad, i wish i had more insight. good luck
Re: replaced starter 4 times, car no go? hlp pls! (jimbones)
is the starter not turning at all? Is the exciter wire from the altenator connected?
Discussion Starter · #4 ·
not turning at all and yes it has a brand new bushing. The exciter wire, would that be one of the 2 wires(minus batterry cable) that plug into the solenoid, if so,i think , but will deffinately look into that,
thanks
it would still start without the alternator exciter wire
make sure you have the solenoid activation wire on the right connector
and also make sure the mounting surface for the starter is clean, so it has a good ground
after that add a ground wire to the starter straight to the battery
Re: replaced starter 4 times, car no go? hlp pls! (verboten1)
can you hear the solenoid engaging? also: does the engine turn over at all, and is the starter getting hot upon repeated start attempts?
1 - 6 of 6 Posts
