replacement bulb for lowbeam in hella dual rounds?
585 Views 2 Replies 2 Participants Last post by  pele
someone said i need to get "h1" bulbs. if this is correct, is there a specific type i should look for? my friend showed me a listing somewhere with 100watt as well as 130 watt. which is preferred?
1 - 3 of 3 Posts
Re: replacement bulb for lowbeam in hella dual rounds? (pele)
H1 yes that is what it should be.
I would stay with the stock 55w why?
#1 that is the rated wattage the optics are made for and using more most probably sooner or later will damage the optical parts.
#2 you will be giving oncoming traffic more glare and mostly its not legal for good reasons.
#3 if you need more lighting I would try to put the highwer wattage in the HIGHBEAM when you actually NEED the light.
H1 bulb:
See less See more
Re: replacement bulb for lowbeam in hella dual rounds? (Cullen)
your the man!. gonna run to the store right now
thanks alot
See less See more
1 - 3 of 3 Posts
