1 - 6 of 6 Posts
My front struts are dead, instead of buying OEM I want to buy Aftermarket struts, what should i get? I want to continue using the 337 springs, so i need struts that are perfectly tuned with the 337 springs.
I heard Eibach Pro damper are 100% compat. is this true?
Re: Replacement struts for 337 springs (turbocharge20v)
You can use bilstein. If you want 100% compact, use the OEM strut.
koni or bilstien will work great, I think koni has a group buy right now in the classifieds
I believe that the eibach pro kit should be perfect, because I think that the 337 springs are the same as the eibach ones. the ride should be a little stiffer, but no harsh, just what it is SUPPOSED to feel like. could be wrong though...
Re: Replacement struts for 337 springs (FLYGTI325)
Eibach springs are not the same as the 337 ones. Different spring rate.
I'm in the same boat as you and I will be getting a full set of KONI SPORTS all around...
1 - 6 of 6 Posts
