Re: Replacing brake pads (Triple777)
The front left has the brake wear sensor, I just cut mine, clipped the wires and fooled the system. Mintex does have front brakes for the car (11.0" and 11.3"). All you'll need is a 7mm hex bit to take off the caliper bolts, and maybe a tool to spread the caliper piston. There is no wear sensor in the back.
BTW, have you thought of trying Porterfield pads? I'm running EBCs and once these wear out, Porterfields will be on the car. I'm only hearing great things about them.
