1 - 2 of 2 Posts
Banned
Discussion Starter #1
seriously...im not good with electrical/wiring stuff...i dont want to just start pulling on stuff...
anyhow
i noticed driver side high beam is out...i go to replace it ...but when i opened the rubber cap..i dont see anything where i can pull out the bulb...there is a connector and a few wires......its probably simple...but i want to be positive i wont screw anything up...so how do you replace the bulb for the high beam on hella dual rounds....i took off the rubber cap...whats next?thanks in advance http://****************.com/smile/emthup.gif
Re: replacing hella dual round high beam bulb? :I (WRC Dorikin)
aiight..
after you take off the rubber there is a paperclip like clip that holds the light onto the housing..
its in a U shape.. the bottom of the U is holding the bulb in.. ant the tips are attached..
squeeze the tips together and itll come loose..
pull out the bulb.. unplug and replace.. put it back in.. put the clip back.. rubber back..
Dunny Dun dun scout!... hope that helps some..
1 - 2 of 2 Posts
