The weld-through primer I bought is copper-based. Paint supplier offered both copper and zinc to me, I did copper because I'd seen more of that used in other places. It was quite expensive...
That's the good stuff costs more but according the person who did the welding on FrankenWagen it's the only thing he uses for his personal work.
Finished the seat mods today. Or at least the mods to the seats themselves are complete. Will decide the best way to reverse the front mounts on the truck's crossmembers tomorrow.Spent a bit of time on the Mk3 seat conversion this afternoon. Got the passenger seat pan done. Will do the same on the driver's seat soon, then reassemble them all. (Need to leave the completed side apart so I can use it as a guide.)
Converting Mk3 seats for a Mk1 has 2 parts. One is that you need to narrow the rear slider track by about 2⅛" (to 18⅞"). The excess all needs to come off the outboard side. The other thing that's needed is to reverse the side that the slider release operates on. On standard seats it's pretty simple (minor fabrication) to do that by swapping the release levers on the 2 seats. That's what was done to the Passat seats my truck came with.
But on my new seats, the driver's side is height adjustable, which makes it far more difficult to do the lever swap. So I'm going to swap the front mounts on the floor from side to side instead. Should be fairly simple to cut them off and weld them back on the other side, since I'm going to be welding new pans in anyway.
And finally today, I finished the first side. The driver's side seat mount is now in place and fully functional. Now that I know what I'm doing, I should be able to finish the passenger side tomorrow.Still working on the front-center seat mount swap. Those mounts are more solidly attached to the body than pretty much anything else I've seen on this truck. They are welded with 6 nice fat bead welds and at least 2 spot welds each. Having to really give some thought to how I need to do this and make the end result as stout as the factory did. Much more involved than I expected.
That's a good idea. I figured I save the original DPR as a spare anyway, so if I decide I need to tune it, I think swapping it out first makes sense. Thanks for the prompt!Just a thought, you may want to to play with the original DPR and not the one that came with the fuel distributor. If anything goes wrong, you can go back to the stock one.
