I used rubbing compound first, then I used a high deet insect repellent, it may take a few goes to get them where you want them. I didn't have the right tools for the job.
For about 4 weeks, on a Saturday morning, I did them with the repellent. Then I thought better leaving the repellent to eat at the oxide build up was the best elbow grease. That's why it was over 4 weeks. They've oxidised a wee bit now but that's normal, I live in the northern tropics of Australia, they all do.
I used a bit of rubbing compound at the beginning which worked a treat. I then used a non-scratch scourer and microfiber cloth to clean up in between the scourer. I coated them in the repellent because when it dries it's protection against the oxidation process. It worked wonders for me after a lot of different recommended crap I bought for them.
I will get them sanded back soon I think, just for my piece of mind really (I am getting a full-body re-spray). I will continue with the repellent after they're done though, every 12 months or so to maintain them.
Be sure to spray on the scourer to eliminate it going on your paint work. Highly recommend a power tool do the scrubbing & polishing.
Given my Jet is currently in surgery, he's having a make-over under the hood & full re-spray, polish etc etc, he'll be ****-hot soon. I can't tell you too much about whether the repellent has eaten the paint work. I wasn't super-careful but I did tape around the actual headlight to avoid any repellent on the paint work. I would be super-careful if he wasn't being re-sprayed.
It's been worth it, the repellent worked very well and cleared all of the oxidation and has kept any oxidation building up.
Good luck.
