1 - 5 of 5 Posts
Discussion Starter #1
I had my revo big turbo software takin out, and returned all hardware to stock except still has a greddy front mount intercooler. Here are all the codes that are set. The car seems to run ok, perhaps you can hear a notciable misfire at idle, but thats about it. The CEL comes on about 20 minutes after driving. Thanks for anyhelp!!
Car is 2003 GTI 1.8t 20th anniv. AWP engine code.
This was taken from the engine module.
Control Module Part Number: 06A 906 032 PL
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 07510
Work Shop Code: WSC 77879
Additional Info: 9BWKE61J734065886 VWZ7Z0C7131348
11 Faults Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
16622 - Shareware Version. To Decode all DTCs
P0238 - 35-10 - Please Register/Activate - Intermittent
17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too low
P1103 - 35-10 - Please Register/Activate - Intermittent
16497 - Intake Air Temp. Sensor (G42): Signal too High
P0113 - 35-10 - - - Intermittent
17608 - Shareware Version. To Decode all DTCs
P1200 - 35-10 - Please Register/Activate - Intermittent
17645 - Shareware Version. To Decode all DTCs
P1237 - 35-10 - Please Register/Activate - Intermittent
17647 - Fuel Injector for Cylinder 3 (N32): Open Circuit
P1239 - 35-10 - - - Intermittent
17648 - Shareware Version. To Decode all DTCs
P1240 - 35-10 - Please Register/Activate - Intermittent
17646 - Shareware Version. To Decode all DTCs
P1238 - 35-10 - Please Register/Activate - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16514 - Shareware Version. To Decode all DTCs
P0130 - 35-00 - Please Register/Activate
Discussion Starter #3
Re: Returned to stock from Big Turbo, codes galore! (Theresias)
Well I pretty much figured out what the codes mean, from my friend that has the full version, thanks though. Looking for guidance as to what the combo of codes mean. I'll post the scan from my buddies full vag com asap.
1 - 5 of 5 Posts
