1 - 4 of 4 Posts
as stated when i shift in to reverse my lights dont come on any more, i got a ticket beacuse of it too. i checked/ replaced the bulbs there fine and all the plugs in the tail lights seem to be in. not sure where to go from here?
any input much appreciated
thanks jesse
Re: reverse lights? no longer working, help please (northwestVR6)
Two things to check.
1. Fuse (probably not the problem)
2. Backup light switch that is attached to the top of the tranny (more than likely broken)
Re: reverse lights? no longer working, help please (eli10)
look for the plug that goes into the **** tower....i have seen it happen were one of the wires in side of the plug (look at the end of the plug) the wire will get pushed down and no longer make contact. push it back up, and plug it back in.
keep your fingers crossed, it's probably the fuse
1 - 4 of 4 Posts
