1 - 4 of 4 Posts
As the title says, please list your settings i.e. LB9 T5, 1% idle, 3% run, 165g/s.
Just wanna make sure I'm within range of the norm.
Thanks dubbers,
Re: revo users, what are your block 032 and 002? (fccn75)
I'm running LB9 and timing 7 with water injection. My idle is .8% and my run is 0%. I didn't measure 002.
You should only be concerned if your idle and run values are outside of +/-10%. And even if they are, if you know why, it's not a problem. I ran consistently with my run value at -13.7% with my supercharger. The only time you should get a code is if your are at the maximum limits of +/-25%.
Re: revo users, what are your block 032 and 002? (JettaRed)
Yup mine is holding at -18.8% without the maf and no code for richness. I usually dont see the code unless it exceeds -20%
This info is just for trim information in general as I am not running revo software.
Discussion Starter · #4 ·
http://****************.com/smile/emthup.gif That's pretty amazing with run = 0%.
I sure like to see that in my testing but it's hovering around -7%. This means I'm getting less air than optimal??
Is that water injection inside the intake manifold or is that misting the IC?
1 - 4 of 4 Posts
