1 - 6 of 6 Posts
Discussion Starter #1
Evening all
I have just recently retro fitted a Bluetooth module to my car (VW CC) following upgrade to RNS510 unit...
Manged to get the Bluetooth unit installed and spliced the wiring according.
Haven't activated via VCDS yet however I'm noticing some strange things happening...
The optical parking sensors and temperature display don't always show up on the unit... some times it works fine and others it displays a message saying somthing like "climate information cannot be shown at this time" similar for optical parking...
All other functions work no problem I.e. sat nav, radio etc... MFD display for sat nav etc works OK too...
Scanned for fault codes but doesn't show anything.
I was thinking bad connection on wiring but they all look OK... which wiring controls these display functions on the RNS? The Canbus ones?
Any help appreciated!
Shakey
Sent from my SM-G935F using Tapatalk
I haven't messed with VCDS yet, but messing with data, you have to enable the feature. I think there is a cheaper product you can use too which can activate features.
Discussion Starter #4
Yeah I've sorted enabling the module. It's just this error which is still persistent. No dash warning or anything so no ideas where to start checking...
Have you checked out the VCDS threads? There may be some info in there!
hello
did you end up finding a fix for the messages?
The optical parking system is not available at present and temperature settings cannot be display at the moment.
i have the same happening to my RNS510
thanks.
A.
1 - 6 of 6 Posts
