Ok, here's the skinny...
So the car (I thought was developing a rod knock)... The noise was consistent slight knocking inside the block, cold hot etc. The oil light/buzzer comes on between 2-3k rpms. If you rev the motor above 3k the oil light shuts off. (The engine has 5qts of fresh 10W 40 oil). The engine has been running fine for the last year or so... No noticeable changes.
Yesterday, the car started and made an awful clanking noise upon startup in the morning. So I let it warm up and the noise went away. So I left for work and didn't hear the noise again. Drove six miles, the engine warmed up an ran just like normal. Took it home and same thing, except no noise at startup and drove home no abnormal noises.
Then I went to take my girlfriend to the store and the engine started fine (it was already warm) backed out of the parking space and the noise started again (the clanking) so as I was driving out of the parking lot I noticed that the noise was consistent with the tapping sensation I was getting out of the gas pedal. Then shortly down the road I also noticed that whatever the noise was coming from seemed to be robbing the engine of power. When it would clank and rattle the engine was having a very hard time accelerating??
The engine got overheated once, in my possession (before that ??) and I replaced the headgasket, and that was over a year ago. I replaced the T-belt and tensioner last Thanksgiving. Been running fine till now.
My thoughts were to pull the pan and see if what's breaking is repairable. But I'd like to know if anyone has had this problem or if anyone has had these symtoms, so that I can treat the problem quickly, if fixable. The engine has around 200k on it and I bought it from somebody that blew the auto trans because they didnt' know it needed oil...
so it's maintenance has been well, a tad neglected before me.
I am buildiing an 09A 16V for the 8V replacement however I need the car for about another month, before I can tear it down.
Any ideas or help greatly apppreciated! Thx
