1 - 9 of 9 Posts
im refering to the big bolts that grab the block
im pretty sure its a 9mm cause 8 is too small and a 10mm wont fit on the braket
ive been to every hardware and auto store in the tri-state and cant find 9mm bolts anywhere
how did you guys get your hands on them???
Re: ROSS trigger bracket, where the hell do i get the bolts? (jazzpur)
I use the CV joint bolts,they are same pitch as the hex head bolts,but are round head with allen or 12 point internal drive,just go to Lowes,or a VW junkyard and get the round head allen bolts like I mentioned,works everytime...........
Re: ROSS trigger bracket, where the hell do i get the bolts? (Holy Piston)
I never installed it on Mk4 so I hope that makes sense,if not,then get the hole machined bigger dia and stick whatever bolt you can in the recess.
Discussion Starter · #4 ·
its should be the same block as an aba
but im pretty they are 9mm...which is a bolt that they dont sell anywhere
Modified by jazzpur at 10:39 PM 2-14-2004
Are you sure that they aren't 10mm? Thats what I used when I tried to use that bracket, I tapped threads into the bracket for the bolts to fit.
Modified by Hugh Gordon at 7:37 PM 2-19-2004
Re: ROSS trigger bracket, where the hell do i get the bolts? (Hugh Gordon)
if imagestation work I could show you a pic of mine...I dont remember what size bolts we used but what Holy Piston say should be right...I think I used an 8mm bolt where I mounted mine.. but i mounted mine towards the back of the engine
Re: ROSS trigger bracket, where the hell do i get the bolts? (evolveVW)
If you email me the pic..I can post it for you http://****************.com/smile/emthup.gif
1 - 9 of 9 Posts
