I started my car this morning and drove to work. I'm in SF Bay Area, so it's not that cold. I heard knocking sounds coming from the engine at a stop light. I lightly tapped on the accelerator to hear it better. My commute is short (3 miles), so I gingerly cruised there. I didn't try to accelerate and it didn't seem like I was suffering from loss of power either. I opened the hood and let it idol at work and couldn't really hear the knocking sound.
I downloaded the code when I got to work. After that I started the engine again and it sounded pretty normal. I'm due for my oil/filter change (~5500 miles).
Here are the codes. Any reasons to worry, or is this an one-time thing?
2 Faults Found:
001322 - Camshaft Adj. Bank 1 Intake
P052A - 001 - Cold-Start Timing not Reached
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 40648 km
Time Indication: 0
Date: 2015.06.19
Time: 07:07:43
Freeze Frame:
RPM: 1179 /min
Load: 46.6 %
Speed: 10.0 km/h
Temperature: 26.0°C
Temperature: 18.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.605 V
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 - 008 - Incorrect Correlation - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 40648 km
Time Indication: 0
Date: 2015.06.19
Time: 07:08:23
Freeze Frame:
RPM: 2187 /min
Load: 8.2 %
Speed: 41.0 km/h
Temperature: 39.0°C
Temperature: 19.0°C
Voltage: 14.605 V
Thanks,
Pat
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 40648 km
Time Indication: 0
Date: 2015.06.19
Time: 07:07:43
Freeze Frame:
RPM: 1179 /min
Load: 46.6 %
Speed: 10.0 km/h
Temperature: 26.0°C
Temperature: 18.0°C
Voltage: 14.605 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 40648 km
Time Indication: 0
Date: 2015.06.19
Time: 07:08:23
Freeze Frame:
RPM: 2187 /min
Load: 8.2 %
Speed: 41.0 km/h
Temperature: 39.0°C
Temperature: 19.0°C
Voltage: 14.605 V
Thanks,
Pat
