FV-QR
There is also a by-product of fitting the RS4 valve and this is that it alters the pressure in the in-tank low pressure pump. The OEM low pressure fuel pump before the valve was fitted started off at 4.5bar pressure, but gradually dropped to around 3.4bar pressure at higher revs when WOT. After the RS4 valve was fitted the in-tank pressure stabilised at between 4.1-3.9 bar across the entire run whilst WOT. This too could point to where you would get a drop in power around 5krpm as the in-tank low pressure fuel pump drops below 3.5bar around those revs, which is outside normal parameters and MAY cause fuel cuts or the ECU to back off the power.
The RS4 valve can cope with up to 150bar of pressure requests (GIAC Extreme Beta file testing), which is the limit of the high pressure fuel pumps anyway.
I must stress that all this is from readings taken from live logging on my car, but the diagnosis is subjective although compelling in the logic.
The valve costs under £50, but is a pig to fit as it is located under the intake manifold and at an awkward angle to reach with spanners. I for one think it was worth it, just for peace of mind that it eliminated another variable from the "power dip syndrome"
