1 - 5 of 5 Posts
K i have a Mk4 gti and i just put on a new air filter cuz my old one came off. Check engine is on and code scanner reads:
16795=2nd arr injection sys incorrect flow
p 0411-35-10 intermittet
17536=Fuel Trim bank 1 (multi) sys too lean
p 1128-35-00-
Is it most likely the MAF? i dnt know what else it could be
Re: Running lean/Boostn low (BoOsTedMk4)
i would guess the maf but bump for you to find out http://****************.com/smile/emthup.gif
Discussion Starter · #4 ·
Re: Running lean/Boostn low (bubbagti)
bump for u to find out?...also i just put on the new maf and its running even worse..ahh! lol i have no idea...i havnt reset any codes tho, i was wondering if the check engine would turn off but it didnt and things arnt better... do i need to reset the codes? or is it not the maf?
Modified by BoOsTedMk4 at 7:31 AM 5-21-2004
it was the maf! and cars running great now....i reset the codes with a code scanner and everything seems to be working great.....are the codes i reset any different than readyness codes...i heard some things about those codes but i dnt know much about them
1 - 5 of 5 Posts
