1 - 4 of 4 Posts
We've been authorized to extend our sale on the Solo-Werks S1 Coilovers!
Corrado Solo-Werks S1 Coilovers
Retail: $599
$499 Shipped within the continental United States
CLICK HERE TO ORDER!!!
Features at A Glance
- Front & Rear 45-85mm (1.8-3.4") Lowering Range
- Heavy Gold Zinc Plated Housings
- 400lbs Front Spring Rate
- 285lbs Rear Spring Rate
- Slotted Front Spindle Mount for camber adjustment
- Silver spring perches - double lock ring design
- Platform Specific Spring Rates and Matched Valving
- 3 year Limited Warranty
Product Details
Designed by a joint engineering staff from Germany and the USA, the S1 coilover is built for the enthusiast
that is looking for an ideal balance of ride quality and performance.
In the front the S1 coilover for the MK2, MK3 VW/Audi Group platform features 400 lb/inch
spring rate matched to a twin tube low pressure gas damper mounted in a
heavy gold zinc plated threaded coilover housing that provides not only
great handling, but also exceptional corrosion resistance.
The rear features a 285 lb/inch coil spring & helper spring matched with a
specially tuned sport damper mounted inside the rear version of the
high quality heavy gold zinc plated threaded coilover housing.
1 - 4 of 4 Posts
