My scirocco started running like absolute crap last fall early winter. I just thought it was cold weather + old tune up and sat it. I don't drive it in the winter anyway as our local municipalities have the roads coated in salt all winter.
Fast forward. I changed plugs which are gap around 33, new cap, new rotor. I left the wires on since they didn't look bad. I doubt that is my problem but I will hit them with a multimeter to confirm their status.
I had some loose ends as far as my vacuum lines go. I decided to just remove my charcoal canister and I plugged up all lines that were associated with it. My vacuum issue is right before the throttle body. Where do both lines go? I have one plugged but the second went to a light purple hard plastic line that was a dead end near my fender. Not sure what happened but it is slashed so I plugged that line as well.
My car is running in a manner that it could have a vacuum leak and I am trying to figure out where these two line lead. Are they necessary if they are capped off?
I also have found an opening in the top of the upper airbox as shown in the pictures. This has to be a vacuum leak but I am not sure where it goes. I would have to assume that the it goes back to the intake tube but I really don't know.
Here is the picture of the intake tube. I have both blocked off for now but I am pretty sure one of the lines should still be active. Just not sure where.
Here is the mystery line that WAS on the intake boot right in front of the throttle body
Last but not least hole on top of the airbox. I have the purple vacuum line pointing at the hole.
Some help would be greatly appreciated.
