anyone in central nj with a em4f sds willing to help a little. basically i would like to plug my ecu and programer into another car to see if the problem follows the parts. when cold the car starts and will run for 30 seconds then shuts down. start it again and it runs for less time and shuts down again. this will happen 3-4 times untill it will not start at all. have traced it to the spark cutting out, can be seen with a timing light too. its not the coils, i can fire them as per the manual and plug them back in and still no-go. magnet gaps are good, shows seen too and no rpm err message. im in englishtown but will come to wherever you are if you want but i do have a heated garage http://****************.com/smile/emthup.gif
