1 - 5 of 5 Posts
take your distributor down the hardware store and pick up a high temp rubber o-ring that is slightly bigger in diameter.
i did that and have not seen a drop of oil come out. makes it a bit tougher to adjust the timing - but small price to pay
Re: (16V Seattle)
You can replace that seal to start with but most likely it will not fix the problem. The issue with the dizzy is on the inside where the shaft goes through there is a bushing in there that gets worn out and leaks. Do a search on leaky distributor and you should find someone that has fixed one.
EDIT: Read this thread http://forums.vwvortex.com/zerothread?id=648889 http://****************.com/smile/emthup.gif
Modified by speedy841 at 1:15 PM 9-24-2004
1 - 5 of 5 Posts
