1 - 9 of 9 Posts
what does this thing do and where can i locate it? what symptoms will i get if this part is broken?
thanks!!!!!
Re: secondary air pump.... (jun_1.8T)
The VAG-Com should show you codes regarding errors with this system. However the Secondary air system utilizes an air pump, control solinoid and combi valve. It is rare for the air pump to fail, usually it is the combi valve or the vacuum line which controls the combi valve that fails on the MKIV 1.8T.
Discussion Starter · #4 ·
Re: secondary air pump.... ([email protected])
whats going to happen then when the combi valve or vacum line fails? would i feel or notice something......would it throw a code for the VAGCOM? what really does this whole system do?
thanks!!!
if the vacuum line fails, you will receive a "improper air flow - secondary air pump" code ... secondary air pump is just for emissions, btw
Banned
Quote, originally posted by jun_1.8T »
thanks!!!
You get rough idle, sputtering @ cold starts & incorrect air flow injection or something of that sort.
#10 is the kombi valve and #16 is the vacuum line that cracks causing leaks. I had just replaced mine 3 days ago and http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
Discussion Starter · #7 ·
Re: secondary air pump.... (Don R)
thanks a lot DonR!!!!!
you perfectly answered my questions.... http://****************.com/smile/emthup.gif
Quote, originally posted by Don R »
after making my new inlet pipe i dont even have #16 connected on the inlet. the hose is just dangling there. Is that bad?
1 - 9 of 9 Posts
