Secret MFA functions?
1832 Views 30 Replies 20 Participants Last post by  deepfog
Ok, so I was reading in the G/J3 forum about how to bring up more functions on your MFA so I decided to try this. I turned the key to the on position, held in the MFA button turned the key back and then started the car up. After I did this I scrolled through the different functions and they all had crazy numbers. I tried this a couple time and each time the numbers were the same. Any idea what the #'s are...anyone else done this? Kinda cool
See less See more
1 - 20 of 31 Posts
Re: Secret MFA functions? (8vGTI)
I have the link somewhere at home that tells exactly what each thing is.
I'll dig it up and post it later.
Re: Secret MFA functions? (The Red Baron)
That would be sweet! Thanks man! its been driving me nuts all day
See less See more
here ya go!
enjoy: http://users.raketnet.nl/VWCrazy1/mfa/mfa.html
mines bunk, it doesnt work
See less See more
That's awesome, I wonder if it will wqork on all MFA equipped VW's?
Re: Secret MFA functions? (PimpStylin')
Stupid question??....... how do you change the time on the MFA. I tried holding the button, turning the ignition, switching from 1 to 2 modes.... etc etc, and it doesn't say anything in the owner's manual. Help!
See less See more
2
Re: Secret MFA functions? (primogti)
You change the time with the two tiny buttons by the screen. You need to use a paperclip or something.
quote:[HR][/HR]here ya go!
enjoy: http://users.raketnet.nl/VWCrazy1/mfa/mfa.html [HR][/HR]​
what a great way to keep an eye on the kids
. i'm only 29, don't have any ... but if i did.
See less See more
How do you turn the ignition off and then on without the car shutting off? Mine shuts off right away. and if you can wouldnt it screech??
Re: Secret MFA functions? (eastcoastdubs)
quote:[HR][/HR]How do you turn the ignition off and then on without the car shutting off? Mine shuts off right away. and if you can wouldnt it screech??[HR][/HR]​
don't put the key in 'start' again, just back to 'on'
it will catch again, as long as the flywheel is still spinning. the engine takes at least 2/3 of a second to turn off for me.
tom
edit: i'm just a dumbass
[Modified by acafounder, 2:23 AM 11-25-2001]
See less See more
2
Re: Secret MFA functions? (acafounder)
I know that part but with the engine running did you every try to turn it on again? it makes that nuts sound and i know its not good. wont it do that?
Heres what you do: *Hold in the MFA button through this whole process* 1) Turn the key to the on position so just your accesories turn on 2)Turn the key back to the off position 3) Turn the key all the way and start you car 4) After the car is started release the MFA button and you should be in the new mode.
so that page is a lil wrong then. someone fix that before someone ruins there car. http://****************.com/smile/emthup.gif
See less See more
no one has ever had a problem with it before. maybe its just you. try folowig directions. you were told three times in this thread alone the correct way to do it.
quote:[HR][/HR]Heres what you do: *Hold in the MFA button through this whole process* 1) Turn the key to the on position so just your accesories turn on 2)Turn the key back to the off position 3) Turn the key all the way and start you car 4) After the car is started release the MFA button and you should be in the new mode.[HR][/HR]​
THIS is the best way to do it!!!!!! don't try turning your car on and off and on again, I know its possible but its obviously not beneficial to your motor.
See less See more
Re: Secret MFA functions? (MK2NRG)
Damn, how did you bring this thread back? I started this thread when my username was still "8vGTI" Crazy
See less See more
Re: Secret MFA functions? (Rob Vila)
no 'isht, I saw this and thought "hmm someone's got Rob's old screen name....
"The page cannot be found"
Anyone else having these problems? I don't have MFA but i'd like to know what this mode will show me.
1 - 20 of 31 Posts
