One set of 4 Tire pressure sensors. Perfect for installing on a set of new wheels or wheels with snow tires. The seals for the tire pressure sensors are 1 time use. This means if you swap the sensors from your original wheels you will need to buy a set of seals for each sensor. This can cost $25 per sensor for new seals. Purchasing this set of 4 new sensor is the most economical solution available to get a genuine VW sensor.
Order here
https://deutscheautoparts.com/vw-audi-tpms-tire-pressure-sensor-1k0907253d.html/
If you have any questions about VW Tire Pressure sensors take a look here as we have tried to explain more about the system. https://deutscheautoparts.com/vw-audi-tpms-tire-pressure-sensor-1k0907253d.html
This setup New from a dealer is $360.00 this is 64% off!!!!!!!!!
Order here
