i am trying to upgrade my FM mast antenna to a shark fin style on my 09Jetta S 4 door. i don't have satellite radio.
it has the colored plug in style thin antenna cable with a WHITE plug end on it WITHOUT the satellite signal plug if this matters . not the older thick black cable one like on the older cars.
my antenna had a broken mast stuck in the base so i replaced this with a another aftermarket mast style with a brown plug. it required trimming the retaining tab to get it to plug into my original cable. but it does work perfectly.
so far i have tried a newer model one with a white end, i have also also tried one with a green plug and one with a brown plug. i had to cut the retaining tabs to get these to plug into my cable. none of them have worked.
if it matters the antennas i have tried were only for FM signals. i haven't tried using ones with both signal plugs.
am i just buying bad antennas? or should i look for something different?
any suggestions?
THANKS in advance for your input.
any suggestions?
