Hey guys!
The thing is, that when I want to shift to the second gear from neutral (or from other gears 3,4,5,6), I need to release shifter a bit to the right, so it can drop into gear. In general, clutch and gears works just perfectly. If I'm switching into 2d gear from 1st gear - all works fine, because it's in straight line, but if I need to to push shifter all way to the left - it doesn't want to go into 2d gear. No sounds nor grinding, it feels just like mechanical blocking.
Any thoughts?
Amarok 4motion 2015 manual
Any thoughts?
