1 - 14 of 14 Posts
Hi,
My mechanic just told me that my front shocks and lower ball joints are shot. Does anyone have any suggestions/recommendations on what to buy to replace and where to buy?
He said it'd cost ~$1000 if he were to buy/install the parts. He uses JYB? shocks and OEM ball joints.
Thanks, in advance
SK
WAY too much...
parts4vws.com
MKIV Left Ball Joint - 1J0407365C - $35.00
MKIV Right Ball Joint - 1J0407366C - $35.00
shox.com
KYB GR-2 Shocks (all 4 corners) - $267
You should be looking at no more tan $500 all told.
More info on what? I gave you part numbers and prices. Maybe restate your question in a different format.
Ball joints are ball joints...
Shocks are a personal preference. Popular brands are:
Koni (Yellow adjustable, red, FSD, OEM)
Bilstein (Sport, TD)
KYB (AGX, GR-2)
Sachs Boge (OEM)
FYI, Koni, H&R and Billstein = the sheez, KYB is like the ghetto option.
You should theoretically be able to get koni yellows for about $300($450 for the whole car), the ball joints should of course be cheap (I know you can get the whole tie-rod assembly for cheap on ecstuning.com)
Install should be between 2 hours and 3 hours.
And like a previous poster said, if you are ever planning on dropping it, do it now. You should be able to do the whole thing, including quality drop springs for under the $1000 you were quoted.
Also, don't trust that mechanic, those prices are wayyyyy high.
Modified by dremhmrk2 at 5:06 PM 6-20-2006
Re: (reiser)
Quote, originally posted by reiser »
WAY too much...
parts4vws.com
shox.com
SOUND RIGHT
replacing the shocks usually cost around $250
Re: Shocks and lower ball joints (4father)
Quote, originally posted by 4father »
i'm just looking for opinions on brands and what the best replacement parts are for my wolfsburg.
Thanks
OEM ball joints are fine.
If you're looking to do suspension later (lowering springs shocks or coilovers) do it now.
If you're looking to replace what you have and keep the same ride height, I'd recommend Bilstein, Koni Yellows or Koni FSD.
Re: (dremhmrk2)
Quote, originally posted by dremhmrk2 »
WHAT? LOL!!!!
KYB are really freakin good shocks for their money. Just because they are mostly used on JDM cars doesnt mean they are cheap or bad, however the KYB are really good shocks for stock replacement, not for lowering the car since they are for OEM applications.
Re: (Pifiu)
so what would you recommend for a budget install shock-wise (i read the FAQ already). i'm lowering, maybe ~2" all the way around, wanting to stay in the $400 range for all four shocks. i was looking at the Koni FSD kit, but that's about $200 more than i want to spend.
1 - 14 of 14 Posts
