1 - 11 of 11 Posts
I am looking into a short shifter. There is autotech, neuspeed, and diesilgeek? What are te differnces and what is suppoe to be better? what doy uo haveand do you like it? for what reason do yu or do you not like it? thanks for th help.
Re: short shifter (jetta28962)
The TT part is OEM, and it's the cheapest one you'll find, around $40.
I have the neuspeed short shifter on my car. it's great and i love it. cuts the throw by about 50%. it can be a bit notchy at times b/c of the short moment arm but it's much better and more fun than stock. i would definitely recommend it. good quality and easy install too!
Re: short shifter (HaYNveedub)
i have the dieselgeek. if i remember it is $150 up front, then $50 is refunded to you when you return the 2 parts you just replaced. the kit parts are actual OEM parts, just slightly modified to shorten the throws. extremely easy install. 20 mins if you have the right tools. shorter throws and shorter side to side.
[Modified by VW Pilot, 8:45 PM 4-10-2002]
1 - 11 of 11 Posts
