looking for a short shifter lever....I'm tired of using the stock lever on mine....i was thinking of cutting but re-threading is a bitch...any suggestions???
Are you looking for a shorter throw, or just a shorter shaft?looking for a short shifter lever....I'm tired of using the stock lever on mine....i was thinking of cutting but re-threading is a bitch...any suggestions???
I suppose you could thread it with both CW and CCW threads to try to create the texture that the shift knob needs to grip. Or you could use a Dremel very carefully.there is no threads on the shifter...so rethreading it is not going to help.
I cut mine down as well and changed the boot. I cut it right before the notch ends so i can just follow the notch left and re-notch it. I reused the stock knob as well. Feels great but now its missing a weighted knob.I cut mine. pretty sick. NLS short shift as well. But I went with the OSir light up shift knob with the screw in attachment. You can do a sloppy job cutting it and it wont make a difference. It take A LOT of cutting though. I went through 2 metal hacksaw blades. Dremel FTW.
