1 - 5 of 5 Posts
Are there alternative cranks to the factory ones that are shorter. I've been meaning to swap mine as i cannot roll up/down my window without hitting the dash.
I've never seen shorter ones. Less leverage would be annoying for sure.
I assume you've swapped your dash for something that protrudes?
Discussion Starter · #4 ·
you are correct. I can still open and close it, but it rubbs against dash quite hard. I just wanted something few mm shorter.
Do we know if there are other car brands that fit directly on the spline. That way I can see if somebody makes an alternative for those?
That's a good question. It would be surprising to me if 924 cranks don't fit. Maybe other early Porsche as well but the 924 was really a Volkswagen.
Im sure you could get some CNCed but might be expensive.
1 - 5 of 5 Posts
