Re: shorter shifter? (quicksilver2.0)
Hacking off the gear shift lever does not make for a short shifter. What you would end up with is a short gear shift lever. This does not result in shorter gear shift travel, and it does result in making the effort necessary to shift gears increasing.
A short shifter, is comprises of one or two modified shift linkage levers under the hood which results in shorter gear shift travel.
Modified by germancarnut51 at 3:00 PM 8-11-2008
