Will have pics upi within the next few days. Its just a ton of parts!!!
1990 G06 Corrado-Black, 5spd, tan leather 150K. needs windshield and dent pulled from fender on drivers side. Engine and tranny are currently out going in within the next 2 weeks
Feeler- 93 Audi 90 cs Quattro Black, 5spd, and Tan leather. 127k.
I just replaced the ignition switch, starter, alternator, fuel pump, fuel pump relay, plugs, wires, new rear pads, front control arm bushings, strut bearings, and rear wheel bearings
G60 Engine-
1-Locked up PG bottom end(rods and crank still good, broken rings)
1-PG long block less accessories(needs a valve job) around 86K on it
2-G60 fleywheels( one with 35k old clutch and pressure plate)
2-G60 cams both with approximately 75-80K on them
1-G60 custom cat back exhaust with no resonator and a dual tip DTN style muffler
2-Hollow G60 Cat converters
1-G60 valve cover
1-G60 Intercooler
1-G60 Automatic TB with TPS
4-Digi injector cups(NEW)
1-BBM RSR outlet kit(like new)
1-Neuspeed gladder inlet(less filter)
1-Eurosport race header with O2 bung,was crarcked(has since been repaired and reinforced)
OBDI ABA-
1-ABA long block less accessories approximately 87K on it
Audi AAH V6 and Quattro parts
1-AAH V6 engine complete less accessories with approximately 75K
1-5spd Quattro tranny out of a 94 Audi 90 CS quattro approximately 75k with clutch and flywheel
MISC Engine-
1-16V upper intake manifold with TB
1-OBDII VR6 valve cover(aluminum)80% polished
1-Remains of a 16v top end rebuild kit
1-16v passat straight through resonator
1-New MAF with housing for any 99and up 1.8T
2-OBDII VR6 coilpacks(used, sealed with silicone)
1-OBDII MAF housing
2 OBDII VR MAF's
1-Eaton M90 supercharger with outlet
1-Toyota All-trac A/W IC setup
12- 3" 90* polished mandel bend Aluminum elbows
18-3" Silicone couplerswith hose clamps
1-140* 3" silicone elbow
1-3"-2.5" silicone adapter
Randon silicone couplers
Random 2-4 inch piping
Misc engine and car wiring harnesses.
DIG2 engine harnesses and ECU
Corrado parts-
1-Reiger 3 slat grille with integrated eybrow
1-RS G60 bumper(fiberglass)
1-RS VR6 bumper(fiberglass)
2-Stock G60 front bumpers
1-Rear G60 bumper
1-Set of G60 Euro Lights
1-Set G60 amber turns
1-Bonrath Cup spoiler(fiberglass)RARE
1-Yellow G60 drvers fender(freshly painted)
1-Yellow G60 Hood(freshly painted)
1-Black G60drivers door with glass and regulator
1-Black G60 pass door with glass and regulator
Both sides rear 1/4 glass
1-Black hatch with glass(no spoiler setup)
Both sides rear seatbelt assemblies
Driver and pass Auto seatbelt Assemblies
1-Set windshield trim
1-Black G60 Dash shell
1-Set of g60 dash plastic(painted silver)
1-Set heater controls
1-Shift surround with Yellow leather shift boot and shift lock
1-Complete G60 rear beam
1-Set G60 control arms
1-Rear G60 subframe
1-Front subframe
1-G60 steering rack with lines
Both sides tierod assemblies
1-Shift box with cables and pedal assembly
92 Passat-
1-Complete blue interior
1- blue dash shell
1-Complete rear beam
1-Rear subframe
1-Steering rack with lines
1-Pass side control arm
Complete set steering knuckles with rotor and calipers
Drivers and Pass side window glass
Pass frnt anf rear doors Steel Blue
1-Trunk lid with spoiler Steel Blue
1-Rear bumper Steel blue
1-Fuse box
1- Guage cluster with 130K
Rear window glass
Wheels-
1 Set of 4 ADR concept wheels 17x7 with 200 mile old Toyo Proxes Fz4
1-Set of 4 Snow Flakes with good Dunlop 195/55-14
1-16x7.5 Borbet Type T
G60 Engine-
1-G60 valve cover
1-G60 Intercooler
OBDI ABA-
MISC Engine-
1-OBDII MAF housing
2 OBDII VR MAF's
Corrado parts-
1-Rear G60 bumper
1-Rear G60 subframe
1-Front subframe
92 Passat-
1- blue dash shell
1-Rear subframe
1-Fuse box
Rear window glass
Wheels-
