Re: FV-QR (Slowkums)
There are 2 G20 owners on this site, me and InfinitiG
I have a 1995 (P10 chassis) G20t. 5 speed. I've had it for just over 5 years now and has 240K Km's. I daily drive it and usually put around 400kms a week on it. Touring has limited slip, power leather seats, fold down rear seats, fogs, spoiler.
My car is stock so no point in posting pics. Everything still works on it, all electrics, a/c, limited slip, power seats etc. Just the usual maintenance and things that eventually go. Clutch was done once, water pump, fuel pump, starter have all been replaced. For the most part the car is easy to work on. The clutch and water pump was done at the dealer, but the other stuff you could do on your own.
Last weekend a friend and I replaced an upper control arm, end link bushings, front and rear sway bar. Handles like new again. Even with the stock setup the car handles very well.
The SR20DE is reliable, returns decent gas mileage and likes to rev. The only things I have done was replace the valve cover gasket and get the upgraded timing chain tensioner. Check SR20DE forums for any info.
The stock headlights are horrible though. If you can find some JDM, UK, or Euro ones with manual adjusters that would be a hell of an upgrade.
I haven't had any problems with the transmission. Unlike most of the VW's I've owned, I don't have problems with getting into 1st gear. Some have had 5th gear pop out but I've never had that. There is a fix for that though.
Don't bother with the automatic, not that fun to drive, slow and uninspiring.
edit: My friend has the one and only T4 in Canada. It's an awd G20, actually it's a Nissan Primera imported from Japan. HP10 chassis.
Modified by VWVan at 11:10 AM 4-26-2010
