1 - 5 of 5 Posts
i just got a '93 corrado slc with 125K miles. One problem i have noticed is that when i park and turn the key all the way to the left, then engine will cut off, but the radio remains on and the seat belts don't move forward. But if i pull the key partially out and jiggle it some, then everything turns off normally. Does anyone know what could be causing this? just an intermitent switch?
Ben
Re: shut off problem (vdubin90)
but sometimes i can take the key all the way out and the seatbelts don't move. and if the radio is wired to be on all the time, then why does it turn off when i jiggle the key instead of having to push the off button? it is not the stock radio by the way.
· Premium Member
Re: shut off problem (Benh11)
Heh... this was pretty funny.
He took the key out of the ignition, the lights and everything stayed on, including the radio. He put the key back in, jiggled it around, and then everything turned off.
Weird.
1 - 5 of 5 Posts
