Replace your heat hardened PCV Breather Hose with the better flowing and more durable Silicone PCV Breather Hose on your vehicle for fewer headaches under the hood!
Click HERE for your New ECS Silicone Upper PCV Hose Kit
If your VW or Audi is suffering from a cracked or brittle PCV Breather hose, or you just hate to mess with the factory clip-on style fittings, the ECS Silicone PCV Breather Hose is just for you!
This hose is molded to OEM specifications and is a direct replacement to the failure prone and heat hardened breather that is universally disliked.
Our silicone hose is capable of withstanding much greater temperatures and is inherently more flexible in its design, with the added benefits of improved airflow and less turbulence! Update your PCV Breather hose today!
VW MK5 GTI/Jetta, B6 Passat and EOS - 2.0T FSI Engine ONLY
Audi B7 A4, MK2 TT, 8p A3 - 2.0T FSI Engine ONLY
