1 - 20 of 30 Posts
Discussion Starter #1
I was trying to explain to a friend last night the difference between valves and cylinders, between 8 and 16vs and why one would be better over the other... but could not explain it well, other than the general "the more the merrier"
so, lets get started on this. who's first?
Re: Silly Question = Good Topic: How Does a Valve Work? (deliriousGTI)
Only the first and last cylinders are running right, the cam lobes should not be directly opposed as in those middle cylinders!!!
[Modified by PA 16v, 9:19 PM 12-3-2002]
Discussion Starter #5
Re: Silly Question = Good Topic: How Does a Valve Work? (rockin16v)
Woah, that rocks man!!!!
thank you!
ugh, that hurts my head to watch for too long.
Re: Silly Question = Good Topic: How Does a Valve Work? (PA 16v)
quote:[HR][/HR]Only the first and last cylinders are running right, the cam lobes should not be directly opposed as in those middle cylinders!!!
[HR][/HR]​
Yeah, cylinders 2 and 3 have no power stroke.
http://****************.com/smile/emthdown.gif
Re: Silly Question = Good Topic: How Does a Valve Work? (dianalynnxk)
quote:[HR][/HR]I was trying to explain to a friend last night the difference between valves and cylinders, between 8 and 16vs and why one would be better over the other... but could not explain it well, other than the general "the more the merrier"
[HR][/HR]​
an engine is basically an air pump, and the more efficiently you can pump air thru it the more power it will produce. the 16v motor allows more air volume in and out of the cylinders, thus increasing power.
super sweet graphic, BTW!
Re: Silly Question = Good Topic: How Does a Valve Work? (gearhead455)
http://****************.com/smile/emthdown.gif [HR][/HR]​
well technically it is incorrect since there is no block or cylinders. in fact...what's turning the cam?
it's a conceptual 3D model. and no i didnt do it. i wish i did.
Discussion Starter #9
quote:[HR][/HR]well technically it is incorrect since there is no block or cylinders. in fact...what's turning the cam?
[HR][/HR]​
Hehehehe
uhm, the air riight? isn't that all a car needs to run?
*snickers*
this is cool, now I can show him and explain it and actually make sense.
quote:[HR][/HR]http://www.howstuffworks.com/category.htm?cat=Eng[HR][/HR]​
The image at that link is really good.
Here is another one with simpler graphics.
http://www.keveney.com/otto.html
To attempt to anwer why more valves are better: The whole goal is to get more air/fuel into the combustion chamber. A larger hole (port) and valve head will flow more air/fuel, but there is a limit to how large one intake and one exhaust valve can be for a given bore diameter. So by using more valves more flow area can be obtained in the space available. Also a four or five valve head makes putting the spark plug in the center easier which helps get a more complete burn of the air/fuel. Hope that helps and is accurate enough not to mislead anyone.
Re: Silly Question = Good Topic: How Does a Valve Work? (ValveFloat)
http://****************.com/smile/emthup.gif [HR][/HR]​
Bwahahahaha! That one is wrong too!!
A PRIZE to the first one that spots the huge flaw!!
Besides no intake rocker.
[Modified by gearhead455, 6:42 PM 12-4-2002]
Discussion Starter #13
uhm the cam is on the bottom? shouldn't there be cams on the top, not the bottom?
Nah, that is just like a old camshaft in the block inline 6 cylinder with timing gears.
VERY close but no, The square thing is the condensor and should be grounded.
Go here: VW Engines and click on the Flash 5. A window opens then click Engines 101.
Give him a Coffee straw and a Slurpee straw. Have him breath in and blow out through each. Ask him which one was easier. That should answer his questions.
quote:[HR][/HR]A PRIZE to the first one that spots the huge flaw!![HR][/HR]​
I know!!!
The Head and Block are one peice!
Do I win the prize?
[Modified by MEDEL514, 1:50 PM 12-4-2002]
1 - 20 of 30 Posts
