1 - 6 of 6 Posts
Slave Cylinder Installation Questions
When installing a slave cylinder on a VR6 do you have to bleed the lines? Is the fluid in the lines the same as a the brake fluid? And is this the one that bolts to the tranny?
Please help so I can fix for Waterfest!!!
Thanks.
Modified by jkcorradovr6 at 10:33 PM 7-15-2003
Re: Slave Cylinder Installation Questions (jkcorradovr6)
To bleed a slave you do it the same way as if you were bleeding brakes. Pump the pedal to build some pressure. open the bleeder. It also helps when you open the bleeder to push on the piston on the slave to get a better bleed
1 - 6 of 6 Posts
