1 - 5 of 5 Posts
i just went through inspection and failed for a couple things, one of which was slow wipers. is it a motor problem? relay? any help is always appreciated.
thanks
Re: slow wipers (synthsis)
If its not the motor it could be the linkages which are rusted and need a good shot of WD-40 to get them going again. You can always unplug the wires going to the wiper motor and measure the volts. if you have less than 12 you have a problem somewhere.
Also check the resistor reducing the volts according the stalk position.
The relay is just for the intermident speed.
1 - 5 of 5 Posts
