Re: SNS guys - Wideband question (KeithMac)
Quote, originally posted by KeithMac » |
Also if you only give the correction +/-10 say from a set table (so if the sensor miss-reads you`re not dangerously lean) you`re not gaining a lot? |
True enough, but the idea was to be able to change boost, flow, or fuel pressure and injector configurations without having to change the chip everytime.
Based on a set table, the fi pulse width is very dependant on a known or measured boost, fuel pressure, injector size, and a known flow at a given RPM. If you change either the flow amount (port the head, change to a 16v head, etc.) or change the boost pressure (pulley), you need a new chip to stay somewhat close to optimal under open loop (table) mode. Now possibly the SnS chips can well adjust enough to boost pressure changes (within a certain range), but there is nothing (I'm aware of) that will adjust to the flow. The only way I know to adjust for that is to use a wideband O2 sensor and actually detect what's happening real-time.
True, the old digi 1 may not have enough cycles to do this, so the question may be moot. I know they were working with wideband a few years ago - but back then, WB sensors were a lot more expensive.
