1 - 9 of 9 Posts
Wassup people,
I just got the ISV reroute, 3.5 FPR, 68 mm pulley, and an sns stage 4 chip installed. Is this chip as suitable for this set up without a cam? Any feedback would be greatly appreciated.
Thanks in advance.
Re: SNS Stage 4 chip with no cam ? (corardog60)
yes sure you can ! But you car will run richer when above 3000rpm for sure, so performance will not be adequate and Fuel mixture too. I recommend a cam for best performance and fuel economy.
Re: (corardog60)
i have an idea, why dont you IM the owner of the company, mrkrad.
Also, next time try the g60 forum for a question like this
-Greg
Re: SNS Stage 4 chip with no cam ? (TBT-PassatG60)
That's exatly what I said
Just a bit less kick-in when on throttle than a perfect air/fuel mixture and a louder FHHRRRRRRR coming from fuel pressure due to added fuel! No damage at all, except your spark plug fouling with carbon deposit faster if you rev it often ! Buy a A/F guauge to dial-in the pedal when accelerating to promote better acceleration and fuel economy... I run stage 3 without cam even if it's programmed for it, and I know when fuel mixture is ok just by the way my engine pull when I get on gaz wisely !!
Re: (sold on expense)
Quote, originally posted by sold on expense »
It'll run rich and eventually foul your O2 sensor and cat.
they aren't running THAT rich.
we've sold dozens and dozens to non cam cars.
they work just fine and save you the expense of replacing the chip when you do install a cam later on.
1 - 9 of 9 Posts
