81 - 100 of 391 Posts
Nine diesels of which five are MK1 VWs
Also,
If someone could please tell me what I am doing wrong, and how to embed the videos so it’s not just a link...
I've struggled with this too. The good news is that they are embedded, when you view from a smartphone, or at least they are on my phone.
Another one of the mysteries of the vortex, along with 'how do I get a coolio dancing GIF avatar?'
I have noticed recently that I see broken images, particularly Flickr, but other people comment on the photos, so clearly they see them. The solution I have found is to view from Tapatalk, which often solves the problem.
Kudos on all the recent work and thanks for sharing. 😎
Serial car rescuer, repeat offender
Click the little Video button (next to the picture button). Paste the URL into the field.
Discussion Starter · #83 ·
Thanks mokoosh!
And I am using Tapatalk. They virtually force you on a phone...
The post screen on Mobile phone Tapatalk doesn’t have the video embed. I was reading it’s supposed to be automatic?
In place of the video embed button there is.....
A gif selector. ......
Oh my how have I been missing out on this.
Discussion Starter · #85 ·
Well.
What do you know.
More bs issues!
https://m.youtube.com/watch?v=QXqGlZq0X-s
Chasing an intermittent leak from my injection pump....
To replace the injection pump head seal one must measure timing.
To measure timing on an ahu with a dial indicator one must remove breather pipe.
Upon removal the O-ring on pipe had swollen and would no longer go back on.
O-ring unavailable for purchase.
Must either get new pipe ($40 dealer/$20 China)
Found some O-rings but none quite thick enough.
So I make a fix out of plumbing fittings welded to the 1.6d fuel pump block off plate.
https://m.youtube.com/watch?v=ByJkTBDcQcQ
Apparatus made and installed!
Only to find out that my pre-filter by the fuel tank was causing a serious restriction.
Was only 2, (ok maybe 3?) years old.
https://m.youtube.com/watch?v=doINTN9TmLw
Fuel barely, drips through!
Lame!
Why can’t **** stay good forever god damnit
When am I going to learn and install a fuel line gauge in the cab....
But that’s so much work!
You know I’m goona spill diesel inside the cab...
But oh boy.
I bet she is going to run so. Much. Happier.
And all this for a trip I probably won’t even have to refuel on....
It sounds like you are blaming the part for doing it's job. Did the filter fail causing the restriction or did it do it's job and plug up? If it did it's job, you should pay homage to the soldier and place it reverently in the garbage. :D
Many manufacturers recommend to replace the diesel fuel filters every two years. I suspect that it would be easier to swap out the filter every other year vs installing more stuff that may fail.
Usually a pre filter is installed that is more porous since its there just to get the big chunks out of the fuel. The main filter is used for the final 'cleaning'. Was the pre filter designed to be used as a main or pre filter?
Yes, the more parts you add, the more points of failure.
Discussion Starter · #87 ·
I went out and gave the brave soldier a solute.
I agree it’s probably not the right filter..
I suspect it to be less- fine at filtering than the primary diesel filter in the bay.
Have you ever run dual filters in parallel?
I have been toying with the idea...
I also have been on the verge of adding a lift pump. ...
But I have reserved that until there is an actual problem.
Thanks for checking in!
Discussion Starter · #88 ·
But yeah, twice as many points to leak...
I started doing the pre-filter after working on some old Mercedes.
Which reminds me. I used to use the 300sd specific filter....
Then I ran out and had a hard time restocking. ..
Just too easy to walk down to a parts store than deal with ordering online.
Especially since my debit card had a hold on it.
That took almost a month of faxing and waiting bs to resolve.
Believe me. I got an excuse for anything.
The older Mercedes had three filters. The one in the tank [as porous as a screen door], the prefilter, and the main filter. On the 15k services, we would change the main and prefilter. We would only check/clean the tank filter if there was a problem. Usually a complaint of no power. Usually it was clogged with algae. If you followed their expensive service recommendations, you would never have an issue with clogged fuel filters. Of course, that depends on if the client is using good/clean fuel. Lots of farmers out there.
We also used a Redline product to 'clean' the fuel system. As a flat-rate technician, I would pour the Redline in the main fuel filter before I installed the new filter. We called it the Redline cocktail. The main reason was to save time during starting. Since they did not have in-tank pump, you had to crank over the engine a long time before it fired up to life [a good flat rate battery test]. The cocktail cut that time in half.
I would never own a VW diesel but if I did, I would follow Mercedes lead without the tank filter. I would change them out every other oil service. If they plugged up before that, I would removed the tank and fix the issue [or lines]. Today's diesel/gas is filtered before it gets to the pump nozzle, way more than the 80's. Fuel filters do not plug up in 15-20k without having another issue. It's a symptom of a problem.
I have never added parallel filters. I would not see a reason to do that. You are not producing 1000HP and probably never will.
I'm not certain if I would add a lift pump since the outlet of the tank is at the bottom of the tank. I do not think it's a bad idea, but I'm usually on top of maintenance and if one fuel hose went bad on a 30yo car, all the fuel hoses would be replaced. The only reason for a lift pump is that you have a leak on the intake side of the pump and you would be drawing air. Adding a lift pump is a bandaid. Again, I do not think it's a bad idea because I see the other benefits it may have [easier priming when working on the fuel system].
Discussion Starter · #90 ·
Your right.
I probably do have something up inside my tank.
I have not taken it out since I owned it. (10 years)
But since I saw a pine needle go through the fuel line I am sure someone removed the screen although it looks like it’s never been off.
I mostly had my truck parked last two years.
Put more miles (several thousand) on my $30 bicycle
I made sure to leave the fuel tank full and drive it on a good drive every weekend. At least.
The only thing that is stopping me from adding a giant fuel cell is the fact that
A- original tank never left me stranded
B- the fuel gauge works a TREAT.
It has considerably more high-rev power after replacing the filter. It probably had less than 4,000 miles on it..
I usually pre- fill my filter with ATF
And also add an oz of 2 stroke oil right before I fill the tank.
I get what you mean about the old Mercedes being a pain to prime!
Jacking up the rear as high as you can helps.
One thing about the lift pump, I have a Land Rover 300tdi injection pump.
And those came standard with a lift pump....
Some of those guys are astounded I’ve been running that pump without one for many years.
Have passed on the trick of adding a “T” and a check valve around the pump so it can still suck if the pump fails.
Been doing that since mk4 PD lift pump nonsense that turns the engine off.
Hey Butcher, thanks for checking in!
You have a legendary well respected opinion
Maybe consider a vw diesel someday.
Discussion Starter · #92 ·
So, after another another 5 years after leaning on my caddy to take me away.
She is kind enough to still carry around me as well as my bourdons.
I took a trip to try to let my (now ex) partner figure herself out.
I got to take a beautiful trip with my dog.
And even though it makes me very sad to close the door behind me I am lucky enough to have beautiful things to look forward to.
Not to mention all the positive feelings I have received from fellow mk1 members.
So I was out for about two weeks.
But this shall begin a new phase in my life.
It began with a camping trip.
First was to the willamette national Forrest.
At the cougar reservoir.
It was a free camping spot.
Hardly saw another car.
Very peaceful although I was pretty much rained on 90% of the time.
https://m.youtube.com/watch?v=1u-CViVNb28
Discussion Starter · #93 ·
Next spot was just up river from brookings Oregon.
One of my favorite spots to rest by the coast.
The river goes up into a steep valley that completely blocks any wind.
It is a completely serene place to collect your thoughts.
Now. I’m not saying I was able to collect my thoughts. ...
But if one had a clear thinking mind.
This place would only complement it.
https://m.youtube.com/watch?v=m4_pel3vidU
Discussion Starter · #94 ·
Next was exciting going up 299 from the coast up into Shasta in Northern California.
I should have stayed 2 nights but hindsight and all.
The truck seemed smoother and smoother.
I am very happy to report zero problems with my battery relocated to behind the seat.
150a circuit breaker is all good for a diesel mk1 system.
It takes me about a week to begin coming into my own on the road.
It’s a whole different rhythm.
As a marathon runner and avid trainer it is mighty hard to maintain motivation to run while on the road.
It’s not so bad if you have a camp already set up but a day of driving and setting camp really cramps motivation to train.
And if you do you literally eat when you get back and pass out.
It’s been a couple years and I’m getting rusty.
My truck was too.
But the trucks never been as strong as it is.
https://m.youtube.com/watch?v=aQVwNcEq8HA
Discussion Starter · #95 ·
Final spot before my destination was just off the side of lake Shasta on a little stream and national park camp ground.
Very peaceful spot with lots of cool
Logging trails to explore.
Only thing freaked me out was when a tarantula crawled up the inside wall of my tent and woke up because it cast a shadow on my face from the sun rising.
I might have stayed here multiple nights however the national park camp grounds were closing for the year.
https://m.youtube.com/watch?v=j_lRWqG3qLk
And that’s all I have now.
I was invited to a sweet little ranch that had a stable of rabbit trucks!
We tried to get one of the project trucks running but it has mad compression issues unfortunately. But... the engine is really clean outside and inside. It’s super solid virtually zero rust besides one spot on the a-pillar
Poor little guy. But engines can be fixed. It’s reassuring to see such a collection of candidates to build.
To cap it off with a gem, mokoosh and I traded trucks on my way back and we carved some canyons through incredible scenery.
His truck felt brand new in the suspension.
It was so incredibly quiet and smooth.
Sound deadening was so impressive.
I gotta get me some bilsteins for the front.
His 020 made me feel like my 02a cable clutch was broken haha.
His truck is a 1.9na and had plenty of guts.
I followed while mokoosh led in my caddy and it was a BLAST to see him puff some smoke and disappear even though I was WOT.
He gave the compliment of saying it was a “race truck” haha.
It can be tuned to be way faster. That’s the fun.
But anyways. Nothing broke.
Covered 1200 miles. Nothing for a Tdi.
Nothing for a mk1.
Mokoosh gave me some koni shocks what more can you ask for.
What amazing vehicles and community.
I hope everyone can meet someone as cool as I have.
I have no idea what kind of karma my little truck stored up but I’m sticking the f*** by her.
https://m.youtube.com/watch?v=iD4bOiggdW4
Here is a clip of my turbo system doing its thing.
Had to do some fine tuning
But I am getting there.
I was really impressed with all of the custom brackets, hoses, and shields going on under the hood. The injection pump was so shiny, that I thought there was a diesel leak. Nope, just clean.
I still don't understand your turbo system or the dual boost guages, even though you did explain it to me more than once. All I know is that the guages were moving, often at different times and in different directions, and making a ton of power. I went a little faster than I ever have in my own truck, and it clearly could have done more.
Hats off to your skills sir.
