Well, I swapped wheels, and the TPMS error message was driving me nuts. I messed around trying to disable TPMS for 20-30 minutes last night, and i got both the light and the error message to go away!
Warning: Doing these modifications may cause damage to your car, and may negatively impact your warranty. Do at your own risk!
-To get rid of the light, disable TPMS in the Can Gateway's long coding.
-To get rid of the error message, go into the TPMS module 65, go to the output test, go through a few different tests until you see one that says "System Switched Off". Do that test, and then shut off the car, and remove the key. then exit from vag-com. After that, the error message didn't pop up again.
I got the idea from here:
http://forums.vwvortex.com/zerothread?id=2947319
