1 - 20 of 180 Posts
Re: So, I put together a little guide for the tweaks that ... (Digital Treesloth)
I tried to desable the light washers ,So I did the disable the Xenon with shutter and my lights went crazy...
I think I will just leave the spritzers on
Modified by BigWaveDave at 4:22 AM 10-3-2006
Re: So, I put together a little guide for the tweaks that ... (BigWaveDave)
Don't trust this to be easily found again, so I printed it out. Great info. Thank you. http://****************.com/smile/emthup.gif
Re: So, I put together a little guide for the tweaks that can be done via the Vag-Com (D.Passat00)
this is great stuff ....
....thanks a lot for posting this....this will cut out the need to read hundreds of vag-com posts ..... http://****************.com/smile/emthup.gif
here's a six pack for ya ......
Modified by sox1_4eva at 9:43 AM 10-3-2006
Discussion Starter · #8 ·
Re: (Supplicium)
i wanted to get some people's thoughts on it first before i made a pdf. maybe i missed something, or something isn't correct. i know that there are some vag-com experts on this forum who have a lot more experience tweaking the mkv than i do!
i know i left out the power steering tweak because it doesn't work on the 07's.
Thanks for your hard work. http://****************.com/smile/emthup.gif
Discussion Starter · #17 ·
Re: (2 liter weedeater T)
Quote, originally posted by 2 liter weedeater T »
Thanks for the info buddy. Do you have the code to work the halogens with the hids as high beams? I thought that what I saw under electronics was hids as flash to pass with halogens. Again great job!!!
i believe they are the same.
Re: (D.Passat00)
what setting's are the 07's at for power steering
1 - 20 of 180 Posts
