would an adapter be able to make them fit?
Quote, originally posted by Trev0rBr » |
i just have castellettes right now |
indeed and i appreciate it, they're 14x7 stock vw et, which is 38 or 42? i forget i have no spacers at all i dunno how much room, its all the same size a stock snowflake with 185/60 tires which are the stock size |
Quote, originally posted by retro_rocket » |
You should be good to go with some 25mm adapters. That would make them 16x7 et27, which shouldn't pose any problems (for reference, 15x7 ATS Cups are commonly et28) though you'll probably want to roll your fenders if you're going low. Or if you run a 20mm adapter you'll be at et32 which shouldn't pose any problems. I run 15x7 et35 and if anything I wouldn't mind having a little more clearance between the wheel and suspension. Tire choice is going to be more crucial for you than anything. 195/45/16 will get you within a few tenths of an inch of the stock rolling diameter. BTW stock Castellettes are 14x6 et 38 - not 14x7. |
